bore out a BMW engine.
8.8K views 12 replies 7 participants last post by  Downbs
#1 ·
Ok I'm not saying I want to do this. But I'm wondering if it can or has been done. Remember back in the old days when people would bore out cylnders and pop in larger pistons.. Does this practice happen any more? Could I turn my 97 528i into a 97 530i by boring out the cylnders and putting on larger pistons? Like old muscle car style real gear head stuff?? Or did that some how die with carburetors?
#2 ·
Bmw cly walls are close together. Especially on the M54, N52, and S54. Even if you could it wouldnt be smart. Besides, the difference between 528i and 530i is intake, ecu and exhaust. The engine itself is identical. Boring out is cost prohibitive especially on a 6cyl thats 15 years old. It would be cheaper to buy a new motor.
#3 ·
It seems to me that you can't get larger displacement by just changing the 3 items you mentioned, you have to either change the bore and or the stroke to go from 2.5 to 3.0....:confused:
#4 ·
I believe the difference between the 2.8L and the 3.0L was the stroke. As stated above it would be more expensive to do the engine work then buy a used 3.0l with all the correct accessories and ECU.
If your 528i is running and you're not thinking about doing this because of some engine issue it would probably be cheaper still to sell your car and just buy a 530i.
Tim
#5 · (Edited)
#6 ·
I've just never heard of it. Oddly enough I'm happy with my 528i it fits my needs well. It just seems like old school tuning has died and I was sort of wondering why. It always sounded like such a fun process really.
#10 ·
I see.
#11 ·
It is possible to buy oversized pistons for BMWs n52 motor so I believe it is possible to overbore the motor, by about 1mm. The 2.5l is 82mm bore by 78.8 mm stroke. The 3l is 85x88mm. So you won't turn a 2.5l into a 3l by boring it. But the other complication is the fact that some "325" cars really have a 3l motor and some have a 2.5l. You have to look it up. If you have a 3l and your car says 325 it has a low rated 3.0l and can have it's output increased without overboring. There are also several ratings for the 2.5l motor so depending on which you have, some increase in power may also be possible.
Overboring is normally done not to increase displacement but, rather, to deal with a badly worn engine.
#12 ·
Years ago I worked for Bekkers Import as a sales manager but also built many of the high performance blocks that were sold. As I recall we had Weisco custom make the pistons for us, I think they will do this for most anyone or they used to. Try contacting them to see what they have to offer these days.
Good luck.
