I have a 2001 540iT Sport with 62000 miles. In the past week I've noticed a high pitched whine, more like a whistle, coming from under the hood. It is not related to the wheels (thought it might be a wheel bearing), but it is directly related to engine speed. Sitting in park, it starts at about 2500 rpm. When the motor is under load it's pretty constant throughout the rpm range.
I am pretty concerned about the noise as there are plenty of things that spin at high speeds in the motor. I have tried to localize the sound, but the noise generated by the fan when the engine is revved up makes it difficult. I am fairy certain it is coming from the front of the engine.
How likely is it that this is the first sign of a failing water pump? I've read a lot about other people's water pump failures ending up with loud clunking, but this is just a whine that follows the engine speed.
Any insight would be much appreciated.
