What would happen if you set the auto HVAC system to regular settings instead of jacking everything up higher. Try setting the stratified air dial located in the dash's center vent in the center...and setting the IHKA control panel at a normal 68-72 degrees F...and selecting AUTO air distribution & fan speed (auto must appear in the fan speed display)...then keep the windows rolled up so that the thermistor (sensor) in the IHKA can regulate the system as designed without having to compensate for other changes or elements.
Also...make sure you don't have a hot drink in the cup holder just below the vent were the thermistor resides inside the IHKA (it's the one on the left side of the control panel).
I forgot to check your model year...but if you have the stratified air dial on the vent at the rear of the center console...then make sure it's not set into the blue, too...dial it back to the center or 1-2 dots into the red.
We know that that hot air can come from the floor vents in the summer if the stratified air dial is turned all the way into the blue...and if the dash vents are directed where extreme cold air flows down the front of the dash...and the cold air gets drawn into the IHKA...this can falsely tell the IHKA that the cabin temp is cold...thus hot air is directed out of the floor vents to compensate.
Perhaps the opposite can occur in certain situations if extreme warmed air is being drawn into the IHKA...and falsely causing the IHKA to think the cabin is warmer than the temp setting.
BTW...the cabin temp doesn't get warmer any faster by setting the temp on 90° F...all you end up doing is shooting past a comfortable setting...then you have to readjust the temp lower or open a window...when the auto system will automatically get the cabin to a comfortable temp just using the auto settings (when the system is working correctly).
If the above fails...have you unlocked your cluster? If yes, then run TEST 7 and keep an eye on your coolant temperature ( it will be in Celsius). Perhaps you have a failing thermostat in the cooling system that is not regulating properly and is opening up and not letting coolant temps rise high enough. I forget off hand what the m62 normally runs at...but this topic is discussed enough that it's been posted Manytimes before...or perhaps someone who knows will chime in with the info.
