E46 touring guy here who has been working on a good friends E65 and E66. Back in January my buddies 760LI started stalling with the well known failed HPFP Diaphragm issue. Quick inspection shows fuel pouring out of the vapor line. I ordered a full rebuilt kit from ebay for $300, rebuilt both pumps, replaced the fuel and return filters and sent the car back.
A month later I followed up with my buddy and heard the car had been parked that it wasn't fixed. So now we're here in July and I want to share my full story as I'm at a total loss here and not sure how/where to continue.
Dec 24 - Replaced in-tank fuel pump as it was making noise. Ordered an OEM pump off getbmwparts and took 3 weeks from Germany.
Jan - Replaced the diaphragms with MagnaFuel MP-9400-03 (one in each). Both blew/same issue after returning the car (milage unknown)
Feb - Rebuilt both HPFP (o-ring + diaphragm kit) + Febi Fuel Filter + Mann Jag return fuel filter (OEM is NLA)
Mar - Received the car back, worked with the ebay seller and he sent me a free set of diaphragms. Those blew after driving for 10 minutes.
Apr - Ordered a set of "rebuilt" pumps off ebay China for 300 a piece. Items took a month to arrive, both were used, not rebuilt and one had a failed original diaphragm. I filed a claim, got my money back and didn't have to return the pumps.
June - Ordered an OEM Fuel filter off FCP, item is 4 weeks out. Found a NOS off ebay (Mahle brand) and item received. I tested both fuel filters and FPR to better understand if its a failed FPR (to much pressure) that is blowing the diaphragms??
Post test - FEBI is louder but both were showing 6 bar which is with-in spec from the N73 Fuel Pump PDF thats been shared here.
Ordered another set of ebay diaphragms ($175 for a set), cleaned both pumps well, primed properly. cleared codes. Drove 10 miles and both pump diaphragms are spewing fuel = failed again.
Some important facts:
Please take a look at my photos. Not sure what to do next but I'm 6+ months of working with this car, over 1k in parts throwing and out of ideas.
- Both pumps were rebuilt off the car and cleaned. top 5 pt bolts are torqued to 75 in-lbs. The last set I did at 100 in-lbs.
- feed fuel filter replaced now twice, OEM installed and tested at 6 bar
- Return fuel filter is NLA. I went with a Mann (WK613) Jag filter that is the same size/length.
- All lines have been installed correctly, no mismatch feed/return, etc.
- Return back to tank line was vacuumed out to ensure FPR had proper engine vacuum
- 3 way solenoid value has been tested working (I have a Saab one but haven't changed it as the nipple sizes are smaller than the E66
- Both HPFP's are showing requested and actual fuel pressures as expected after the first rebuild (engine runs great besides fuel dumping back into the Evap solenoid->manifold
- No codes, have reset adaptations with ISTA-D (INPA doesn't offer this option)
