How to change date display from European to American format?
4.7K views 3 replies 2 participants last post by  Calif65GM
#1 ·
With a non- i-drive car, the date displays on the radio in the center of the car. It currently shows in European format (day.month.year). How do you change to American format for the date (day.month.year)(e.g., 3.15.2006 rather than 15.3.2006)? Thanks for your thoughts.
#2 ·
Press the menu button on the radio and then select "Config".
Press the button under "Time" and it gives you format choices. Press the button below the date format that you want.
#4 ·
fundrive said:
Thanks for the reply - however - this only allows you to change the date, BUT does not allow you to change the DATE FORMAT from European to American. Any other ideas anyone?
Ooop sorry it's in the Manual on pg 62.
You actually use the turn signal stalk.
