Engine Removal Lift Points
1 reading
53K views 7 replies 4 participants last post by  dgomez89
#1 ·
Hello everyone, I am currently in the process of taking the engine out of my 2001 325ci. The only thing I am stuck on is the lift points where to take it from? Anyone have any suggestions.
Once i get that information i am ready to yank it out. Please and thank you!
#2 ·
Probably late to the party, but there is a hook right above your tstat next to the intake VANOS solenoid and another one in the back of the engine. Just run a straight edge from the front mounting point to the firewall and look down behind there, it is in line with the front hook point.
#7 ·
Good. The goal is for every user to add value to every job, so that the next person always has an easier time of it than you did. You pay it forward.
A picture of the rear hook would be perfect.
See also:
- Lifting engine without special bracket and trasmission angle?
Here's a red circle around where the rear hook must be, based on the descriptions above.
#8 ·
I found the lift point in the back!! You have to take off the strip on the bottom of the windshield and wiper blades to get a better look down there and much easier to get to the other bell housing bolts. But here is the picture of it I will get another one up soon
