the VERY best of E39 Links
818K views 111 replies 53 participants last post by  Cuzzman
#1 · (Edited)
This post has been deleted
#14 · (Edited)
Somebody already listed this link;
http://www.e38.org/e39/
but it's pretty much everything you every wanted to know. almost every link on there is worthwhile.
I've been in the middle of doing my valve cover gaskets and this is by far the best guide for V8 engines;
http://www.bimmerboard.com/forums/posts/124059
While you got your valve covers off, have them beadblasted and powdercoated. I found this guy out in Texas who agreed to blast, prime and powder coat both covers for only $40 plus 2 way shipping;
http://www.jerryspowdercoating.com/
Good Luck!
#17 ·
#20 ·
Compiled Links
Useful links
Tried to compile some links by category. Although most of us have them, I thought there are quite a few people who don't. Whoever has good links for parts, DIY, etc, please post them - then we know where to look. Dan encouraged me to post them here. I don't know how to make it so everybody can add links to the categoties below, or create new categories, but here they are. Will update as time goes by.
Autoparts
http://autopartsway.ca/
http://autopartsonline.com/
http://usedbmwparts.com/
http://corner73.com/
http://www.realoem.com/bmw/select.do
http://jlevistreetwerks.com/store/in...0dba951feb0e30
http://worldpac.com/
http://www.bavauto.com/
http://bimmershop.netfirms.com/Bimme...scomm/catalog/
http://www.bimmian.com/canada.htm
http://www.autohausaz.com/
http://www.autopartsway.com/
http://www.bimmer-parts.ca/
http://www.extremems.com/index.html
http://www.pelicanparts.com/
http://getcoolparts.com/
http://www.zdmak.com/wbstore/main.as...W TOOLS&bl=6 BMW specific tools
http://www.1stoptireshop.com/html/etailers.htm Online Tirestores
DIY
http://www.unofficialbmw.com/e36/ele...ce_lights.html
http://www.bimmerdiy.com/
http://www.bmwtips.com/
http://www.bmwtips.com/tipsntricks/t.../Newbiefaq.htm
http://www.dinan540.com/index.html
http://forums.bimmerforums.com/forum...d.php?t=835680 Rear M5 swaybar DIY
http://www.zeckhausen.com/E39_Bearings.htm Front wheel bearings DIY
http://forums.bimmerforums.com/forum...t=DIY+tie+rods Tie Rods DIY
http://forums.bimmerforums.com/forum...d.php?t=605750 e39 Aux Fan Motor Service DIY
http://www.bimmerboard.com/forums/posts/199986 Complete cooling system overhaul (and next link)
http://forums.bimmerforums.com/forum...d.php?t=682975
http://forums.bimmerforums.com/forum...d.php?t=566232 Thrust Arms DIY
http://www.eurosport.org.nz/index.ph...19273#msg19273 Different DIY links
http://www.myscantool.com/dtc/specific/bmw.html OBD II trouble codes
http://www.crazycustoms.com/CRAZYASTRO/obd2.htm Another OBD II trouble codes page
http://www.langka.com/paint_chip_repair.php Chip repair
http://www.bimmerfest.com/forums/sho...d.php?t=233926 Powerflex thrust arm bushings-DIY (Infamous shimmy - cheap version and best)
http://www.540i6.com/finalstagereplacement.html FSU (Final Stage Unit) DIY - no heat in car
http://www.bavauto.com/newsletter/20...newsletter.pdf Fluids maintenance and overhaul
http://bimmer.roadfly.com/bmw/forums/e39/6960596-2.html ATF change a DIY w. Steptronic
http://bimmer.roadfly.com/bmw/forums/e39/5796042-1.html ATF change e46 (similar to e39) very detailed - for filling procedure
http://www.bimmerfest.com/forums/sho...51&postcount=1 Chip repair DIY
http://bmwtips.com/tipsntricks/door/panel.htm Door panel removal DIY
http://bmwtips.com/tipsntricks/Windo.../regulator.htm Window Regulator DIY
http://www.beisansystems.com/procedures/index.html DIY for: Double Vanos 6 Cyl, Thrust arm Bushing, Swing Arm ball Joints, Front Struts, Rear Shocks
Performance,mods & repairs
http://www.stealthauto.com/default.aspx
http://www.zeckhausen.com/BMW/E39.htm
http://www.europeanautosource.com/
http://www.turnermotorsport.com/html/index.asp
http://www.umnitza.com
http://www.vfengineering.com/
http://www.vdorepair.com/
http://thewheelexchange.com/
http://www.tirerack.com
http://www.ca-at.co.uk/products.php?...d=57&comp_id=8
http://www.hoen-usa.com/
#24 · (Edited)
#25 · (Edited)
#27 · (Edited)
This brand new cn90 E39 front suspension DIY is an "instant classic" for shock/strut replacement DIY!
The DIY for building a Garmin GPS icon is off the wall a bit ...
Here is a molding DIY from bimmerfest and one from bimmerforums ...
And, you can't get a simpler front-door passenger-side window-glass replacement DIY
Well, maybe you can ... the world's simplest DIY ... How to avatar on bimmerfest
If your battery goes dead
frequently (especially if your fans are erratic) ...
Why I don't recommend the Motive Vacuum Oil Extractor ...
Some DIY sites for E39 specifically would be useful too.
- http://www.e38.org/e39/
